Create Image with URL
Hi, I’m wondering if “Create Image” component works with files saved on websites instead of local files. Under the current working from home situation, I’m trying to load image from URL, but it doesn’t seem to work.
I’m using the same method for other non-Human UI components loading data from URL, so I believe I’m using the correct file path.
No, it only knows how to access local files at the moment.
Got it. Thanks for the confirmation. I’ll save necessary files under roaming files for each user in my company as a workaround.
