Fantastic that can create own hatches in Rhino WIP, but have noticed that when the tiles repeat there is a slight glitch and the lines are not seamless but a slight ‘bump’.
I’m using Rhino WIP on Mac
Thanks!
Thanks!
Hi Tim,
Can you post a small example of what you are seeing? Thanks.
Hi Tim -
This image is impossible to troubleshoot.
Please post the 3dm file including the geometry that was used to create that hatch pattern.
Wim, how do I attached a 3dm file to this reply? I looked but couldn’t see how to, which is why pasted a screenprint? Thanks! Tim
Thanks!
So, I created a new hatch which was 75mm offset parallel lines and 5000mm long. If you apply this hatch to an area larger than 5000mm then you can see where the hatch tile repeats, so wondering if anyway to make this seamless.
75mm hatch.3dm (61.8 KB)
That’s interesting! Screenprint of mine below, which shows the seam.
And copied SystemInfo below.
Thanks
Rhino 9 SR0 2026-4-14 (Rhino WIP, 9.0.26104.12306, Git hash:master @ 5bd7a4f16954bce589a148ccd941ced83b3638ad)
License type: Educational, build 2026-04-14
License details: Stand-Alone
Expires on: 2026-05-29
Apple macOS Version 26.4.1 (Build 25E253) (Physical RAM: 32GB)
Mac Model Identifier: MacBookPro18,3
Language: en-GB (MacOS default)
.NET 9.0.1
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Pro
Color LCD (1512 x 982 @ 120.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/updaters/libT200Updater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 9.0.26104.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 9.0.26104.12306
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 9.0.26104.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 9.0.26104.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 9.0.26104.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 9.0.26104.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 9.0.26104.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 9.0.26104.12306
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 9.0.26104.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 9.0.26104.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 9.0.26104.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 9.0.26104.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 9.0.26104.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 9.0.26104.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 9.0.26104.12306
