Create diagonal grid extrusion inside brep through intersection
Hello everyone,
I’m trying to solve a problem when intersecting two solids, but I don’t know why is not working.
I want to get the intersection between a diagonal grid extrusion with a rectangle based brep, however the result is a weird selection of some lines from the grid and a warning in the message balloons saying the intersection failed.
I guess I’m forgeting to consider some informationto have this unexpected result.
Could anyone help me to understande why this is happening?
I want to have the diagonal grid only inside the brep.
IN THE IMAGE
I just moved to the side for visualization.
Left: Weird result
Middle: Rectangle base brep
Right: Diagonal Grid
Intersection Diagonal Grid.gh (102.1 KB)
Well …
  1. Fisrt things first: your ortho solids are not good: You have this (surfaces “mixed” with solids):
instead of that:
  1. Other than that what are you trying to do? Perforate a thing like the above with some shapes (offset inwards polylines) yielding a single solid … or create a collection of solids the sum of whom makes a perforated assembly?
Hi Peter,
Sorry for the late answer.
  1. So to make a good solid, I just have to copy what you did in the picture, is that right?
  2. I was trying to create a collection of solids which the sum makes a perforated assembly, so I could control the density of the grid using the width of the solids. The problem is that when I tried to use Solid Intersection, it didn’t create a clean grid only inside the 3 beginning objects.
