Create curve surface from brep
Hi all,
I am trying to generate a curved surface to represent floor plates but getting into issues. It works fine for non-curved objects but cannot form a boundary surface from curved objects.
In addition, I am trying to create floor plates from the building object but not the footprint. Appreciate if there is any idea!!
Floor Plate Creation From Brep.gh (6.9 KB) Floor Plate Creation Test.3dm (143.3 KB)
Best,
-HC
Hi @hoganchan113,
Turns out you don’t even need to do this, but in general the Boundary (Boundary Surface) component should work fine for this.
This can be done a couple of ways!
Since, you have both a building footprint base curve and a brep representing the building volume, you can either copy this base curve to appropriate z-values and extrude it to get the three-dimensional floor plates, or contour the building envelope to get the floor curves first and then extrude them to a desired floor slab height.
This should work with every building envelope in your scene.
Floor Plate Creation From Brep 2.gh (12.4 KB)
Excellent answer! Thanks @diff-arch
