Is there a way to create a ON_Brep object from an ON_Mesh object?
I need the brep to be able to compute the intersection with a plane and generate intersection curves that will be later used for lofting.
Thank you
Thank you
Hi @blondbeer,
The Rhino SDK does provide methods for computing mesh intersections. ON_Mesh::IntersectPlane
comes to mind.
If you really want to create a Brep from a mesh, you can use ON_BrepFromMesh
. This is the function behind Rhino’s MeshToNURB command.
– Dale
