I generated a Delaunay mesh above an extruded volume.
Like this, when I try to 3d-print the plate, the mesh surface is not joined with the rest of the object.
I would like to join the existing volume with the mesh, to get a unique volume. Is there a way to do it?
Thanks in advance
I’m sorry, but the problem I’m talking about is contained in a larger and quite messy file, that’s why I uploaded the preview instead of the algorithm.
The lower volume is an extrusion, the upper surface is a Delaunay mesh created starting from random points.
Ok, i didn’t get that you were asking for the actual file, I thought you were asking for a screenshot of the algorithm, since I’ve seen it in a couple threads on this forum. Sorry for the misunderstanding.
The situation I’m talking about is in this file. Example.gh (13.9 KB)
Thanks
