Create a Toggle for MouseOverHighlight setting
Hi all,
It’s been a while since I’ve scripted, and I’m thinking maybe this has to be done using RhinoCommon (?) which I’m not versed in.
Would anyone be kind enough to furnish a simple script that I could use to create an Alias? And then I could also learn using the script. :slightly_smiling_face:
Thanks in advance!
– Alan
I’m not quite sure what you’re referring to. Do you need a script that detects when you mouse over a highlighted object, one that highlights objects when mousing over them, one that toggles highlighting on or off for another script, or something else entirely?
Thanks,
~CH
Thanks for the reply, @Cole_Howell1 I’d like a simple script to Toggle the setting On/Off.
Thoughts?
Hi @Alan_Farkas, try below script within _EditPythonScript to toggle that setting:
#! python 2
import Rhino
import System
def ToggleMouseOverHighlight():
    # toggles boolean value stored in Options > Advanced
    # Rhino.Options.General.MouseOverHighlight
    try:
        rh_id = Rhino.RhinoApp.CurrentRhinoId
        settings = Rhino.PlugIns.PlugIn.GetPluginSettings(rh_id, False)
        s = settings.GetChild("Options").GetChild("General")
        b = s.GetBool("MouseOverHighlight")
        s.SetBool("MouseOverHighlight", not b)
        print "MouseOverHighlight={}".format(not b)
    except Exception as ex:
        print ex
Save the script to your preferred location and create an alias for it eg. using below macro:
! _-RunPythonScript “C:\MyFolderPath\MyScriptName.py”
_
c.
Thanks as always, @clement Will give it a whirl and confirm here.
