Create a surface between two closed curves
Hello everyone,
I’ve had a look through the forum but haven’t found anything to help me. Maybe it’s a noob question.
I’d like to create a surface between two closed curves, where the second curve is an offset of the first in the xy plane, with vertices filleted to a radius equal to the offset and shifted downwards.
I’ve tried using a loft, but the surface ‘twists’ even though I’ve tried to align the seams:
or I try to rebuild it with control points:
To be honest, I really don’t know how to go about this. Thank you in advance for your help.
Loft_Test.3dm (42.1 KB)
Could something like this help?
no gh needed.. a simple sweep2 with a few slashes added will get you there-
do it with history enabled and you can iterate on the profile shape.
are you specifically wanting to do this in gh?
I didn’t need it specifically in gh I was searching for a solution in Rhino.
Now I just need to figure how to add slashes to maintain the same slope.
Thanks
slashes should use the profile of your original input curves, they simply locate and straighten the isoparms at the location. Use osnaps for more precision.
I used a slightly curved input profile and slashes at each corner that go from the sharp internal curve corner to the mid point of the outer curve for this result.. Do it with history and you can change the profile shape interactively
