Hi, I have an half hull created from 3 curves.
I created Surfaces (NURBS)
A rhino’s website tuto explains:
1- transform NURBS surfaces to mesh
2- Mesh repair Fill holes
3- Mesh boolean union
4- Mesh to NURBS, a solid is created…
BUT not at all!!! the hull disappears!
file 0: shows the simple half hull
file 1: fill all holes: one side has transparent parts
file 2: the other side is normal
file 3: after mesh boolean union!!!
I think the problem comes from the “fill all holes” but I dis not find any tuto explaining how to do correctly…
Thank you Kyle for your help,
As I was testing, I took a basic example.
In the reality my hull is a little bit more complex.
I started with joined curves (also 7 pts degree 6; it’s enough for my accuracy).
I now whish to convert it to solid for various uses.
With my model (included) I do not suceed. If you make a big zoom it appears that surfaces do not join exactly or they overlap. I suspect that it is one (!) reason it is not easy to convert to a solid. This is why I tested mesh / fill holes. Without success.
The R3d tuto is not very useful!! If you have an idea… tests hull to solid.3dm (319.9 KB)
