Hi, All!
I know the “Pt” component can be used as in “Set one point” and that this point/s can be dragged afterwards in the Rhino UI. These kind of points is precisely what I need BUT
Can we give the Pt component an N amount (coming from a lets say “list length”) of points so that it creates a set of N points that we can later on drag?
I know I could create a list of N random point coordinates to create the points, but then I loose the possibility of after-creation-dragging.
Another way would be a sort of sequence that createsANDbakes a set of N points and then incorporates this baked points into the GH def, but I guess this would lead to some looping misheap, won’t it?
Thanks in advance for any help!
BTW, the goal is to create a list of N Breps to which I can afterwards link a list of N data dictionaries I have beforehand…
That´s a 95% solution. If I internalize, the connection to the list origin gets cut.
I “only” have to reattache the list to the points, but my wonder was if it was possible to have it autoupdated so that if I change the dictionaries, and the amount updates, the amount of points automatically changes.
Thanks @jopsa2 the #kangaroo approach might prove very useful for further stages, but for now I think the gumball proposal from @Dani_Abalde will work just fine! Thanks to all!
