Create a Rhino 8 Package using Yak.exe
I am using Yak.exe from https://files.mcneel.com/yak/tools/latest/yak.exe to create a package. I read here that the tag will be created by inspecting the contents of the package by Yak.
What do I have to change in the content of the package to indicate to Yak that I want to build a package for Rhino 8?
I would like to generate packages for Rhino 7 AND 8 from the same source.
Yak will look at the RhinoCommon Nuget package your project references to specify the rhino version which is then added to the yak package name. But you can rename it yourself, if you wish to specify a different version.
ā€“ cs
What Callum mentioned is true. It is also mentioned here
