Hi!
I’d like to modelise a spheric volume, but not full, i’d like to have a thickness of 2 mm.
And, inside the volume, i’d like to make drill, like i show here.
First, i am not sure i am using the best solution for the spheric volume: i am doing four “1/4”, or quarter of volume, anf after, i’d like to assembly doing an addition boolean. But, sometimes, it doesn’t work. So, i am sure there is an easier and quiclky solution!
After that, i’d like to make drill, but, as it is not a plane volume, we cant do for example boolean substraction, we have to create the mesh, in order to have a good geometry. But, after, i don’t know how to do. What i am doing, as i show here, is, step by step, using “réseau de surface” …and after “décaler surface”, 2mm, and after, addition bolean… but it is so long, and i am shure there is a best way!
Can you please help me? Thanks so much!
