Create a curve with a few curves
How would you create a curve using more than 2 curves? Please see screenshot, there might be another way to solve the problem. Thanks!!
Hello - I am not sure I understand what you want but I think it could be that you want to make the red and blue curves follow some undulation as indicated by the wavy curves - if so, try making a NetworkSrf from the grid of wavy curves and then Project the red and blue onto the resulting surface.
Hi Pascal, thank you! i am not sure if what you mean but i did use your commands and made something similar! Thank you!
Can i ask you another question please? How would you then use the red and blue lines to create this ‘twisted’ connection? thank you again!
