Create a center curve of an edge surface
Hi guys,
I am trying to create a center curve out of the edge surface, any idea?
The concept is to model a structural support around the opening using the offset curve from the center line.
thanks
Structural steel support for wall opening.gh (7.5 KB)
You can use the following way to do that, you can make set the extrusion height and so on using wall properties / height etc… to be accurate
Thanks Mohamed, kind regards.
Would it be okay to share the definition? thanks.
Sure thing…
RE_Structural steel support for wall opening.gh (20.5 KB)
Thanks Mohamed, cheers mate.
