My skills in grasshopper are fairly basic but I’m pushing myself to create a slightly complicated form of a neuron network pattern on a curvy facade. Please see the photo attached.
I want this kind of pattern to be on these two surfaces (attached photo+rhino file), not just as a flat pattern, but with some depth like how neurons connect spatially.
I’ve been trying things out with Voronoi 3D, but haven’t quite gotten there yet. I’d also like to add a point/curve attractor to it so that I can have parts that have more neurons and parts that have less.
The good people of Rhino+Grasshopper community, please help me out. Thank you!
yes you need first create plane surface than use surface morph ; with your model it take long time
and you must split your surfaces and choose one part from each surface; grasshopper will detect the full surface
I opened your original definition again and grasshopper says there’s an unrecognised object in the file. It’s Mesh UnifyNormals. Could it be this that doesn’t allow me to bake? I have MeshEdit installed and I can preview the mesh.
ok what you need to do is: to recreate the second one with grasshopper
first you need to separate the ploysurfaces to 2 parts than extract the top and bottom curves; in grasshopper you will rebuild the curves and create new surfaces .
also you need to use Sporph instead of Surface morph
