Creasing / pinching surface along curve
Hi everyone! I’ve been trying to solve a problem for 2-3 days, but this time I couldn’t solve it.
I created this curve (first image) with Kangaroo 2. I want pinch a planar surface along this curve. It must be smooth cavity transitions between peaks. Like this:
Although I thought of many alternative ways, I could not solve it. I made this surface which is somewhat close to what I want:
But on this surface, the troughs between the peaks do not have a smooth transition. There should be no flats in the middle of the cavities.
I made this surface with the divided main curve and its moved division points smoothly in Z axis with closest point. (Zero move towards the edges.) I converted to Nurbs curve the moved points. At the end I did fillet the edges but it didn’t give me the finish which is I wanted.
Thank you in advance for your interest.
