Hi! I’m new in Rhino.
Studying the tutorial level 1, after many tests I do not understand how to create the gasket described at page 143.
How to do after the 6 circles are drawn?
Thank for your help.
michel
First of all thanks a lot for your quick reply.
The model above: I’m trying to create the example described on this page but there is no additional explanation… When I my 6 circles are drawn I do not know how to continue.
Although I have created all the examples presented in the tutorial (before the page 132) I do not see the solution.
Perhaps I’ll have the same problem with the one you show me…
Best regards,
Michel
Rhino tutorial p132.pdf (78 KB)
Hi Michel - the text says
Use Circle, Arc, Trim, Fillet, and Join to create the part shown.
Use Extrude Planar Curve > Straight on the Solid menu to create the 3-D part.
The extrusion thickness is .125.
It looks like you now need to to the Trim
and Join
parts, then ExtrudeCrv
Hi Pascal,
I understand I have to use “trim” and “join” but I don’t succeed to eliminate the red lines.
Thanks
Michel
Hi Michel,
Select all the curves and run the command Trim
Next while in the command click on the parts w=you want to get removed.
DOes that work?
-Willem
Hi Willem,
yes, great!
thanks a lot.
michel
Hi Willem,
I strickly followed explanations in the Rhino tuto (p177) to create a canoe from Loft.3dm file.
The shell command says: the result is not a solid.
I thenk you in advance.
Michel
Hi Michel -sorry - this is really a mistake, basically, in the manual. Shelling was added to a simple exercise to which it is just not suited - please just ignore the shelling part of this lesson.
thanks Pascal!
Michel
