I downloaded the free trial version of V7 which crashes if I try to apply a material to an object, crashes when I open object properties, crashes when rotating an object in perspective view, basically crashes so much I can’t use it.
Moved to a new topic.
Please run the Rhino “SystemInfo” command and post the results.
I suspect you are running an old buggy display driver, but it could be other things.
Rhino 7 SR2 2021-1-12 (Rhino 7, 7.2.21012.11001, Git hash:master @ 2f08cf516ffc716c4c4a369abf7625798ef79bca)
License type: Evaluation, build 2021-01-12
License details: Cloud Zoo
Expires on: 2021-02-26
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Radeon RX Vega (AMD) Memory: 8GB, Driver date: 12-4-2020 (M-D-Y). OpenGL Ver: 4.6.14757 Compatibility Profile Context 20.12.1 27.20.14501.28009
> Accelerated graphics device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 12-4-2020
Driver Version: 27.20.14501.28009
Z-Buffer depth: 24 bits
Total Video Memory: 8176 MB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.20.0
C:\Users\Rob\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.4.1\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.4.1.0
C:\Users\Rob\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ProRender\1.0.0.0\ProRender.Windows.rhp “ProRender” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21012.11001
C:\Users\Rob\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2020.12.7.446\SectionTools.rhp “SectionTools”
Also, I upgraded to V7 from V5 and paid a local Rhino vendor for it. I also entered my license key at Rhino3D.com but systeminfo tells me it’s an evaluation…
Hi Robb, have you tried to turn off the Orca plug-in and then try it?—-Mark
Actually, I would disable all of the Plug-ins in Options > Plugins, filtered for Plug-ins that do not ship with Rhino.
Restart Rhino and see if you can repeat the problem.
Assuming so, then enable them one at a time, restart, and try to repeat the crash.
I’ll have a developer look at the crashes you sent in.
I haven’t seen this before.
You need to remove the evaluation license from your Rhino account and leave your permanent license key in there.
I heard back from a developer.
Please turn off Antialiasing and GPU tessellation in Options > View > OpenGL
It looks like something in the drivers or display pipeline.
Try that without disabling your plug-ins.
Any different?
