Crashing on NewFloatingViewport
The 2017-04-11 version crashes every single time when calling NewFloatingViewport.
Empty model with factory-default template. Both wireframe and shaded viewports.
same here
It is very likely the same cause as
https://mcneel.myjetbrains.com/youtrack/issue/RH-38873
https://mcneel.myjetbrains.com/youtrack/issue/RH-38911
This has already been fixed.
/Nathan
p.s. yup, this was a major screw-up. I am the one to blame.
Thanks, Nathan!
Is this also linked to the WIP crashing when opening 3dm files? (Import works fine, it’s just opening that crashes).
I believe so. If and when the next public WIP is out, and it still is crashy on opening 3dm files you should shout. But over here I am able to open files without seeing crashes.
