Crash with the SetPt command on the camera control points
I have experienced similar crashes over the years. It gets worse when non-Rhino-native render plugins like Maxwell/V-Ray are involved.
Another case of “crash in render preview modes” would be to use the SetPt command on the camera control points, while a live render is running. But that’s a different topic I guess.
Indeed a different topic, so I moved it to a new one of its own.
@DuncanW I tried the following:
  1. simple scene with box
  2. _Camera _Show
  3. Set viewport to Raytraced
  4. Select a camera control point in another viewport
  5. _SetPt, Ok without changing settings
  6. move control point around until happy and select location
I was unable to get Raytraced crashing.
Can you maybe elaborate what you are doing to get this crashing?
Thank you Nathan.
I believe with the more modern Rhino “raytraced” viewports this might be less of a problem. To my experience it’s more to do with render plugins, which may in fact be the reason for the crashes, and not Rhino itself?
In any case, a very rare thing to happen, thankfully. If I work anything out, I’ll share.
Quite possible. We’ll need to see a crashdump to be able to determine what the cause is.
