Crash with block instance on locked layer
Is it normal for Rhino to be so sensitive when having blocks on locked layers?
Hi John,
Are you getting an option to send a crash report?
Please provide systemInfo and steps to repeat what you are seeing. Thanks!
https://discourse.mcneel.com/t/please-read-this-if-you-are-logging-a-bug-or-issue/173971/3
Hi, Japhy! No option, just crash to desktop.
More info: I started from a dwg with many block instances. All of them on two locked layers. Whenever I click on a block instance in the block manager tab that resides on these layers Rhino will crash. Rhino crashes also when switching to the block manager tab if previously a block was selected and then the layer was locked. If the layers are unlocked I don’t have a crash.
If I can find the time I will try to prepare a file for submission.
I’ll try to replicated based on that. Please run SystemInfo command in the Rhino command line and post the results when you get a chance. Thanks
