Crash while opening files
Hi! Did anybody experienced Rhino 8 crashing while opening Rhino 7 files?
Could you please advise what to do to solve the problem?
Hi Petras - please run SystemInfo in Rhino and post the results here. If the problem is specific to some files, please send one to tech@mcneel.com, with a link back to this topic in your comments.
Hi Pascal, do you mean copying everything from Rhino System Information, right?
Help, than System Information, and than copy all?
Hi Petras - yes, please.
does file>import (NOT file>open or double click to open) on the file that is crashing work by any chance?
Rhino 8 SR2 2023-12-12 (Rhino 8, 8.2.23346.13001, Git hash:master @ dbefe46c12cda06610a9ab683a211aa3d16f0030)
License type: Evaluation, build 2023-12-12
License details: Stand-Alone
Expires on: 2024-04-04
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 3.9Gb)
.NET 7.0.0
Primary display and OpenGL: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 10-16-2017 (M-D-Y). OpenGL Ver: 4.3.0 - Build 20.19.15.4835
Primary OpenGL: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 10-16-2017 (M-D-Y). OpenGL Ver: 4.3.0 - Build 20.19.15.4835
> Integrated (slow!) graphics device with 3 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.3 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.3
Shading Language: 4.30 - Build 20.19.15.4835
Driver Date: 10-16-2017
Driver Version: 20.19.15.4835
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.2.23346.13001
All files are crashing while opening them.
Hi! I’ve tried this also, but also keeps crashing. Did you have the same problem?
You’re running the smallest video card possible on an antiquated driver, you might be able to get by if you update and reduce the load on the GPU as much as possible (One Viewport, turning off geometry you aren’t working on, stay in wireframe)
Please see our System Requirements
The file crash may be unrelated, please send us an example if possible. Thanks
This may be helpful when updating the Intel HD driver: Updating Intel HD Driver
Thank you for your help! :slight_smile:
Thank you! :slight_smile:
