Not sure what’s going on here, but I’m getting freezing during TriangulateNonPlanarQuads on a very simple model and need to force quit.
In a larger model, of which this rectangular plane is a part, I got hung up in the dialog boxes—it would not Discard Change or accept OK, so I had to force quit Rhino. I believe I backspaced a value out of the entry field to get the “” invalid message?
Then, TNPQ worked for other parts of the mesh, but not this one which I’ve isolated—a small polygon segment in the image below (with file attached). It appears valid under What. I selected the object and issued TriangulateNonPlanarQuads. It immediately beach balls the program. After about two minutes I get the same dialog box as above, which I can’t dismiss. Must force-quit application.
Figured you might want to know.
~Dave
Test_Fail_Triangulate.3dm (32.9 KB)
Software information
Software versions
Rhinoceros version: 5.0 Wenatchee 2014-03-17 (506)
OS X version: Version 10.7.5 (Build 11G63)
Plug-ins
None
Hardware information
Computer hardware
Hardware model: MacBookPro8,3
Processor: Intel Core i7-2860QM CPU @ 2.50GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: AMD Radeon HD 6770M 1024 MB
Memory: 1024 MB
Screen size: 1920 x 1200, 1920 x 1200
Displays: Cinema HD, Color LCD
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Logitech: USB Receiver
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Western Digital: My Passport 0730
Apple Inc.: iPhone
Apple Computer, Inc.: IR Receiver
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-7.32.12
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: None
