No problems using (7.0.20154.14355, 6/2/2020) which appears to be the newest version available to me.
Loft and Sweep2 produce expected results.
Sweep1 surface twists and does not cloce, but otherwise okay.
LoftSubD produces result which has strange shape. I’m not a SubD user so I can’t comment further.
Perhaps you could run the Rhino command SystemInfo and post the results here. Someone may then have a suggestion. Also try disabling any non-McNeel plugins and see if that solves the problem.
It looks like newer versions of the WIP are not generally availabe yet. When I “Check now” under “Check for updates” the returned message is “This version is the latest available”. When I check https://www.rhino3d.com/download/rhino/wip the version available for download is from 2 June 2020, the same as the version I have. Perhaps the general release of thei week’s update has been delayed.
The latest public Rhino for Windows 7.0 WIP (7.0.20154.14355) was released 7 days ago.
You are running an “internal” daily build and should expect a lot more issues than people that stick to public builds.
We found several crashes occurring in daily builds in the last few days and decided not to release a public build at this time.
