Crash Rhino when processing a large GH file
Hi guys,
I have a big GH file that will crash pretty often. It is connecting to Archicad via the GH-AC Live Connection Addon, but I’m not quite sure which one is causing the crash, Grasshopper or Archicad. As you can see in the attached screenshots, the file is quite complex. Upon opening and connecting to Archicad, it does not crash right away. If I make some adjustment and drop a Panel while waiting for the changes are being updated in Archicad, it will close the whole Rhino.
I’m not sure if this is normal. Should I wait for Archicad to update with the change before dropping anything to GH?
Thank you very much!
Best regards,
Minh
