Good morning! I would like to receive information and help about a problem with the connection.
In both computers Crash is installed correctly, and last version, but when creating the URL and join the model, throws this error:
Also, in the help page, they explain that you cannot transfer files larger than 1MB in weight, but with only 1 basic cylinder, it already weighs 3MB, so, what is the application if I cannot enter a 3D model for example of 200MB?
Crash.Server is the central node that crash plugin instances use to communicate to one another, so you need that somewhere everyone can communicate with. It’s very easy to run, getting it working perfectly may be trickier.
Regarding this
I think likely there’s a connection error. Can you DM me the addres you used so I can try to repeat?
