CPython Eto doesn’t set Class Parameter
Hallo,
i have the Problem when put a Label to the Dialog that the given Parameter by init the Label dosen´t set. When init the Label and than set the Parameter to the Label this work. This is happen in the Rino WIP use RhinoCode. I prefer when is not to match Parameters to give it the Labe when init this. Give a opportunity to change this?
Her my test Code:
import System
import System.Collections.Generic
import Rhino
import Eto.Drawing as drawing
import Eto.Forms as forms
class Test_UI(forms.Dialog[bool]):
    def __init__(self):
        self.Titel = 'Hallo'
        layout = forms.DynamicLayout()
        layout.Spacing = drawing.Size(5,5)
        # This dosen´t work with the Textparameter
        label = forms.Label(Text='Testtext')
        # This work
        label = forms.Label()
        label.Text = 'Hallo'
        layout.AddRow(label, None)
        self.Content = layout
def main():
    dialog = Test_UI()
    dialog.ShowModal(Rhino.UI.RhinoEtoApp.MainWindow)
if __name__ == "__main__":
    main()
Example_Classparameter.py (1.3 KB)
I can confirm this doesn’t work, while it works in Rhino Python.
ps: your
self.Titel
should be
self.Title
in order to work
Yes the with the Title was my mistake. But I mean not the the Title Attribut from the Dialog Class. That was not work is this:
yes, I understood it was about the label, I asked someone else to look into your posted issue as I don’t have a clue why that would fail.
@Till_Richartz
This is NOT supposed to work. Label does not have a constructor that takes text as input. Even if there was a constructor, the parameter name would be lower case like text= not Text=
label = forms.Label(Text='Hallo')
This is the correct way to set the text value:
thanks, I saw indeed that it had no such constructor. Can you explain why it did work when running that code in RhinoPython?
I believe that is a feature of IronPython whereby Properties could be set directly via instantiating that way.
The documentation states:
IronPython also supports inline initializing of the attributes of the instance.
See: IronPython .NET Integration
This is similar to doing in C#:
var lbl = new Label() { Text = "Hallo" };
@Gijs Nathan is correct. IronPython had a series of features like this that are not part of the python specification and thus not supported in Python 3
