Running this script from with ScriptEditor with a seleceted simple mesh crashes rhino silently
remeshing.py (1.4 KB)
This crash is on this line after a long time of processing this call even on a small mesh:
m = pymeshlab.Mesh(verts, faces)
I Although I also do not see an error thrown.
It works on a normal python shell, though.
This is definitely a crash inside pymeshlab
. Whats the python version you are using in normal shell? I installed pymeshlab
in both 3.9 and 3.11 and can’t get this example script from meshlab to work.
Would you mind sharing your example?
import numpy
import pymeshlab
# create a numpy 8x3 array of vertices
# columns are the coordinates (x, y, z)
# every row represents a vertex
verts = numpy.array([
[-0.5, -0.5, -0.5],
[0.5, -0.5, -0.5],
[-0.5, 0.5, -0.5],
[0.5, 0.5, -0.5],
[-0.5, -0.5, 0.5],
[0.5, -0.5, 0.5],
[-0.5, 0.5, 0.5],
[0.5, 0.5, 0.5]])
# create a numpy 12x3 array of faces
# every row represents a face (triangle in this case)
# for every triangle, the index of the vertex
# in the vertex array
faces = numpy.array([
[2, 1, 0],
[1, 2, 3],
[4, 2, 0],
[2, 4, 6],
[1, 4, 0],
[4, 1, 5],
[6, 5, 7],
[5, 6, 4],
[3, 6, 7],
[6, 3, 2],
[5, 3, 7],
[3, 5, 1]])
# create a new Mesh with the two arrays
print(m)
Ok your script worked fine for me on python311 it seems that pymeshlab on python39 has a problem.
