I have come to realise that mastering the Cplane is critical. I need to place the Cplane where the two lines are so i can draw an elevation where the two lines are.
I’m designing a metal box to house the two filters.
Can the Cplane be placed before drawing, or do i need to create something first then attach the Cplane to it, then delete the drawing.
I will need to move and adjust the Cplane around the box for various other parts.
As long as your cplanes are world-top-right-left-bottom-back… set one of these
then in a second step pick a point for _cplane elevation
take care if “project” is on or off.
for free orientation of cplane _cplane _3Point is very powerful.
you can save the cplane in the _namedCplane Panel.
you can look perpendicular in parallel projection onto a cplane with _plan command.
you can drag and drop pictures to the post-edit window.
maybe sketch the desired cplane so it s easier to advice …
Thanks for taking the time. Its a bit of a dark art…so far.
If i use right, left Cplanes the Cplane does stand up on its edge as in my image. I had thought there was a simple way to grab the Cplane and move it to touch the base plate (red).
on the other side i can get it to work because i have pre-placed the vertical lines. Was hoping to be able to quickly move and attach without making the lines.
The box is being designed to have a diagonal split with a lifting lid to access the filters for maintenance. 3mm folded aluminium.
I took these screen shots to show what i was thinking.
