Huh, okay. So the CPlane in the Top View then was somehow rotated? In the Top View, I tried using the CPlane -> Rotate -> X -> 90 commands, but the CPlane did not drop down into the view. I was able to do this in Perspective view, however.
Hi Evan - I am a little in the dark, still, about what is meant to happen - it sounds like the Cplane is vertical, edge on, to the view in one of your views and therefore does not show as you expect in that view. What CPlane should be active in that view? Can’t you just set whatever plane as you like in that view only, and then carry on?
