CPlane make it "stay Active"
Adding text to my new constructed cplane works
When I’m trying to rotate the text is using the world coordinates
Is it the ViewCPlane I should use to fix it, and How do I set it up correctly ?
surface1 = rs.GetObject("Select surface 1", rs.filter.surface | rs.filter.polysurface)
Border1 = rs.DuplicateSurfaceBorder( surface1 )
rs.HideObject(surface1)
bbox = surface1
msurface = rs.SurfaceAreaCentroid(surface1)
point = []
LL = rs.ExplodeCurves(Border1)
for i in LL:
    po = rs.CurveMidPoint(i)
    point.append(po)
newplane = rs.PlaneFromPoints(msurface[0], point[1], point[3])
tx = rs.AddText("22", newplane,height=50,justification=2
#rs.ViewCPlane(newplane)#???
p = 0,0,0
rs.RotateObject(tx, p, 45.0, None, copy=True)
OK so i figured it out… :wink:
view = rs.CurrentView(view=None, return_name=False)
rs.ViewCPlane(view,newplane)
rs.ViewCPlane(view,rs.WorldXYPlane())
Is there a way to do it without updating the viewport ? I mean Is it possible to do without showing in the viewport that the construction plane is changing ?
I am looking for the same thing to freeze viewport, and hide Cplane when it is changing in the script steps.
