Why does the Cplane move each time an object is selected and it is oriented only to that object?
Thank you, there are many changes that are different from R7. Is there a list somewhere to be to familiarize myself with the changes?
Envoyé de mon iPhone
there is also a new in V8 Toolbar at the top-right
Thanks again.
maybe mark this topic as solved - so others don t need to dig in and see that you re happy (hopefully)
kind regards -tom
Hello again Tom,
I just did the update for R8 and opened a drawing from a few months before only to find the image attached. Is this another problem with Metal? The white parts are the true form which was OK in the previous version. The seemingly transparent or dark colored objects appeared when I opened the drawing after the update. I tried copying the white objects and they become as you see a dark transparent version of the white object. Several months ago I had a problem that I showed Brian James where there were ghost objects in places that were different from the true place of the objects, it was a problem with Metal and I donât remember the number he gave it. I hope this will be an easier solution as the previous one took several weeks to solve so working on the drawing in R8 was impossible.
Best
Joe
Hi Joe - please start a new topic for this new question.
