I am trying to use the C-plane Elevation command to raise Linear Dimension above a 3D object so that the line or text is not inside the object and obscured when using the Technical Display mode.
However, all attempts using Elevation I have tried fail. Ditto setting the Cplane to a different point in the FRONT viewport. Tried this a number of time, but I can’t get the dimensions above and away from inside the 3D model. You can see most of the dimensions in wireframe, but switching to Technical obscures the dimensions.
Can anyone suggest what I am doing wrong or better, a work around … like moving my entire dimension layer in a 2D display port ‘to the front’?
All comments appreciated!!!
B
