Cplane 3points and shift key
When using the set cplane 3points mode. the second click responds to ortho but the third click does not.
Bump
Hello - as far as I can tell this works if you use Shift in a view that has a CPlane where it makes sense.
Hi Pascal,
But the command does not work correctly if you are working in the perspective view.
after the second click it should rotate around the X axis and snap to ortho if the shift key is pressed. just like after the first click.
Hello - keep in mind that the ortho applies in the current CPlane, not the one you are creating.
Ok, now it makes sense. thanks Pascal.
