Is there a method to count the number of edges in a surface? I would like to find surfaces that are circular, with only a single edge.
Or maybe there is a better way to select surfaces like those shown above? I should mention that there are a number of other operations happening so I would prefer not to prompt the user to pick anything (as with GetEdgeCurves).
Thanks,
Dan
Hi @DanBayn,
below seems to work:
import Rhino
def MyFilter(rhObject, geometry, componentIndex):
if geometry.AdjacentEdges().Count == 1:
if geometry.AdjacentFaces().Count == 1:
crv = geometry.OuterLoop.Trims[0].Edge.ToNurbsCurve()
rc, circle = Rhino.Geometry.Curve.TryGetCircle(crv, 0.001)
if rc: return True
return False
def DoSomething():
gs = Rhino.Input.Custom.GetObject()
gs.SetCommandPrompt("Select surface with circular trim")
gs.DisablePreSelect()
gs.SubObjectSelect = True
gs.DeselectAllBeforePostSelect = True
gs.GeometryFilter = Rhino.DocObjects.ObjectType.Surface
gs.SetCustomGeometryFilter(MyFilter)
get_rc = gs.GetMultiple(1, 0)
if gs.CommandResult() != Rhino.Commands.Result.Success:
return gs.CommandResult()
elif get_rc == Rhino.Input.GetResult.Object:
for objRef in gs.Objects():
brep_id = objRef.ObjectId
face_index = objRef.GeometryComponentIndex.Index
print "ID: {} >>> Face index: {}".format(brep_id, face_index)
DoSomething()
Btw. instead of a getter, you might just iterate over the brep faces and do the same as MyFilter does.
c.
Hi Clement,
I will give this a try first thing in the morning.
Very much appreciated,
Thanks,
Dan
