Could the two commands to generate the Ribbons be added to the SubD tools: “Ribbon” and “RibbonOffset”?
We would need a better management of the “Ribbon” command, add it to the already present “RibbonOffset” tool.
In particular, “RibbonOffset” only works on closed curves; while the (hidden) “Ribbon” command works on both closed and open curves.
(Also, as I have already pointed out, an instrument icon should be added for “Revolution” SubD).
Thank you
