So, I am fairly new in coding, Rhinoceros and Grasshopper. I took an introductory course as part of a class in my Masters and I thought I was grasping the basics but then this error comes out: 1. Warning (CS0162): Unreachable code detected (line 90). Since I have no background in coding/programing I have been googling and trying to understand what that means. Honestly, I can not follow the explanations online, they are too complex.
What I am trying to do is simple: I want to be able to create random extrusions in which the height depends on the distance to reference point. The closer to the point the higher the extrusion.
I attached my GH file here if everyone can check on Line 90 and explain to me what does the Warning mean.
Thank you.
PS: if anyone knows about some good C# beginners crash courses I am open ears or eyes.
You have a for loop that will never loop because you have a break; at the end. This means the increment will never happen. In short:
for(int i = 0; i < 10; i++) {
// code here
break; // <<- this break just before the end of the loop
// causes the i++ to never be run -> unreachable code.
Get rid of the inner foreach over rectangles, and instead read Rectangle3d rectangle = rectangles[i];. That will get the rectangle for each midpoint you created earlier.
Thanks for clearing up the explanation and the tip. That will help me so much in the future. I have been trying different small codes and I always ended up trying to do a foreach + for loop. I had no idea I could do it as you mentioned. By the way it worked perfectly. Now I just have to adjust my dimensions in the code to make it look better.
