Could Rhino installer exclude certain components?
Would it be possible for Rhino installer to exclude some components? It would be helpful for testing new versions with wine - right now for example WebView2 blocks the installer. I’m not a c# developer, so not sure if that’s a necessary component, but if not it would be useful to exclude it from the installation for testing purposes.
I’d be grateful for your advice - very much aware that it’s not officially supported.
The gitlab page times out, so can’t check out what the exact issue is. But no, there is not a way to skip components in the installer. WebView2 is used in the help system in the very least.
Thank you @nathanletwory for looking into this.
Hmm, that’s strange, this page should be publicly available. I can copy the contents here:
I don’t think it’s quite working yet? Installer stuck: [
Both for wine and wine-staging (ArchLinux).
Any hints as always would be very appreciated. Perhaps some quick’n dirty fixes? (…)
It was confirmed though that WebView2 support isn’t complete, specifically the WldpQueryWindowsLockdownMode function isn’t working.
Sadly, it blocks the rest of the installer and even if it worked all Rhino 8 versions after the rhino_en-us_8.0.22324.16305 run into another issue on start that prevented them from starting and I can’t reach that stage anymore.
