CORS Error when embedding Shape diver
Hi Shapediver Team
I have a technichal issue im wondering if you can assist me with.
Im attempting to embed the Shapediver viewer into a Webflow powered site using
custom components running the script below, however it is returning a CORS error when trying to load sdv.min.js.
You can find the site here :
I looked online and seems some others have encountered this issue with Shapediver but could not find a solution that didnt require reaching out
Please let me know if you have any ideas
Best regards
Chris
Script
<script>
  // Function to load an external script dynamically
  function loadScript(url, callback) {
    var script = document.createElement("script");
    script.src = url;
    script.onload = callback;
    script.onerror = function(e) {
      console.error("Failed to load script:", url, e);
    document.head.appendChild(script);
  // Load the ShapeDiver viewer script and initialize the viewer when done
  loadScript("https://viewer.shapediver.com/v3/3.9.4/sdv.min.js", function() {
    console.log("ShapeDiver script loaded.");
    document.addEventListener("DOMContentLoaded", function() {
      (async function() {
        try {
          const viewer = new SDVApp.ParametricViewer({
            container: document.getElementById("sd-viewer"),
            model: "TICKET HAS BEEN PLACED HERE BUT REMOVED FOR THIS POST", // Replace with your embedding ticket
            showSceneTransition: true
          await viewer.init();
          console.log("ShapeDiver model loaded successfully.");
          // (Optional) Log parameters
          const parameters = await viewer.parameters.get();
          console.log("ShapeDiver parameters:", parameters);
        } catch (error) {
          console.error("Error initializing ShapeDiver viewer:", error);
</script>
It seems you are trying to load the version 3 of the viewer using the viewer 2 documentation (or possibly updating an old implementation of viewer 2 that was already existing). Please have a look at the viewer 3 documentation and, if you had used viewer 2 before, check the migration guide.
