A file I’ve been working on has completely lost all visual use. I can operate Rhino as normal but without any visual change in the viewports, as the viewports are permanently black, ie select objects, run commands, etc etc. I know that the last operation I ran didn’t execute properly, but since I’ve run that I’ve tried saving small and such, so it has no history. It’s also, as far as I’m aware, not system-side as other files work fine. Here is the 3dm audit and the file;
Testing 3dm Archive: C:\Users\Ryan\Documents\school\372\drill\drill.3dm Start Section: 452 bytes (offset 0 to 452) Offset: 0 3dm archive version: 60 Interface Name: Rhinoceros 6.16 - Evaluation, build 2019-07-09 - (compiled Jul 9 2019) SDK Version: 2348836105.2353033197 OpenNURBS Version: 2353033197 3dm Version: 6 Operating System: Windows 10.0 SR0.0 or greater, 64-bit, platform 0, version 10.0 build 0 sp 0.0, suite 0, product type 0 Runtime: ON::RuntimeEnvironment::Windows 3DM I/O processor: OpenNURBS toolkit version 2353033197 (compiled on Jul 9 2019) Properties Section: 1917 bytes (offset 452 to 2369) 3dm archive openNURBS version: 2353033197 (6.16 2019-07-09:1) Application Information: Name: "Rhinoceros 6" URL: "http://www.rhino3d.com" Details: "Evaluation, build 2019-07-09" Revision History: Create Time: Monday July 22 03:54:37 2019 UCT Last Edit Time: Tuesday July 30 19:05:41 2019 UCT Revision Count: 32 Created By: "ryang" Last Edit By: "Ryan" Settings Section: 13551 bytes (offset 2369 to 15920) Length unit system: millimeters Plug-ins: Name: 3Dconnexion 3D Mouse Version: 6.16.19190.07001 Id: DCA0DB8D-844C-48d6-BA97-F5595FE6AFDB File: C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp SDK Version: C++ 2348836105.2353033197 (6.0 2017-08-15:1, 6.16 2019-07-09:1) Name: Commands Version: 6.16.19190.7001 Id: 02BF604D-799C-4cc2-830E-8D72F21B14B7 File: C:\Program Files\Rhino 6\Plug-ins\Commands.rhp SDK Version: .NET 0.0 Name: Displacement Version: Jul 9 2019 07:22:30 Id: F293DE5C-D1FF-467a-9BD1-CAC8EC4B2E6B File: C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp SDK Version: C++ 2348836105.2353033197 (6.0 2017-08-15:1, 6.16 2019-07-09:1) Name: RDK_EtoUI Version: 6.16.19190.7001 Id: 638A0098-0511-482b-95BF-8CF47FD32C17 File: C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp SDK Version: .NET 0.0 Name: Renderer Development Kit Version: Jul 9 2019 07:18:03 Id: 16592D58-4A2F-401d-BF5E-3B87741C1B1B File: C:\Program Files\Rhino 6\Plug-ins\rdk.rhp SDK Version: C++ 2348836105.2353033197 (6.0 2017-08-15:1, 6.16 2019-07-09:1) Name: Renderer Development Kit UI Version: Jul 9 2019 07:19:32 Id: 67755633-23FD-4ac5-A18C-C1F14F0AB05D File: C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp SDK Version: C++ 2348836105.2353033197 (6.0 2017-08-15:1, 6.16 2019-07-09:1) Name: Rhino Render Version: 1.50, Jul 9 2019, 07:19:09 Id: 5DC0192D-73DC-44f5-9141-8E72542E792D File: C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp SDK Version: C++ 2348836105.2353033197 (6.0 2017-08-15:1, 6.16 2019-07-09:1) Name: RhinoCycles Version: 6.16.19190.7001 Id: 9BC28E9E-7A6C-4b8f-A0C6-3D05E02D1B97 File: C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp SDK Version: .NET 0.0 Name: Snapshots Version: Jul 9 2019 07:23:43 Id: 73B88F43-C32C-4306-93B5-1D0082FFFEE8 File: C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp SDK Version: C++ 2348836105.2353033197 (6.0 2017-08-15:1, 6.16 2019-07-09:1) Name: Toolbars Version: 6.16.19190.7001 Id: DC297053-96C0-4883-A688-8326B4E024A8 File: C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp SDK Version: .NET 0.0 Embedded image Table: 0 embedded images, 24 bytes (offset 15920 to 15944) Texture Mapping Table: 0 texture mappings, 24 bytes (offset 15944 to 15968) Material Table: material[0]: Plastic material[1]: Plaster material[2]: Plastic material[3]: Plastic material[4]: Plastic material[5]: Plastic material[6]: Plastic material[7]: Plastic ... material[9]: Plastic 10 materials, 11033 bytes (offset 15968 to 27001) Linetype Table: 0 linetypes, 24 bytes (offset 27001 to 27025) Layer Table: layer[0]: Default layer[1]: construction layer[2]: v2 layer[3]: image layer[4]: Layer 02 layer[5]: model 6 layers, 1506 bytes (offset 27025 to 28531) Group Table: 0 groups, 24 bytes (offset 28531 to 28555) Annotation Style Table: annotation style[0]: Default annotation style[1]: Millimeter Architectural annotation style[2]: Millimeter Large annotation style[3]: Millimeter Small 4 annotation styles, 5594 bytes (offset 28555 to 34149) Light Table: 0 lights, 24 bytes (offset 34149 to 34173) HatchPattern Table: 0 hatchpatterns, 24 bytes (offset 34173 to 34197) Block Definition Table: 0 block definitions, 24 bytes (offset 34197 to 34221) Object Table: object[0]: 55776 bytes, id = 21fcf0cd-a930-4497-b0d9-a9640bc5ce70, name = "" object[1]: 3510 bytes, id = 3c7807e9-77e2-40d1-b7cf-b6b4c3ec1291, name = "IMG_20190729_154636.jpg" object[2]: 727 bytes, id = 632c635f-37d8-435b-87e3-5cff7004dc5c, name = "" object[3]: 395 bytes, id = 7d4de2ea-ada3-4ea8-a419-10b6733f6503, name = "" object[4]: 227 bytes, id = 8e4924f0-6191-41ff-a93e-fb417a8c0f7a, name = "" object[5]: 1982 bytes, id = a02c168a-d146-436e-b1cd-f25edf65369d, name = "" object[6]: 446 bytes, id = c05aa4f9-380a-4cf4-8566-2ed21b74f4e6, name = "" object[7]: 702 bytes, id = 173ababb-b187-4d33-9b7b-119c4fe25326, name = "" object[8]: 2878 bytes, id = aa241033-a9db-4f94-bc34-dd4648de5a10, name = "" object[9]: 926 bytes, id = 0ee4c56e-32b9-4029-b484-6e2ef43d96e7, name = "" object[10]: 542 bytes, id = ac6105ce-9b1c-49dd-9352-e3224df8c146, name = "" object[11]: 929 bytes, id = 86e2527f-6edb-4da6-af0d-f0c3b3871362, name = "" object[12]: 624 bytes, id = db0526ce-d27e-4b1b-a80b-fbf02d2d1db7, name = "" object[13]: 833 bytes, id = a839ade8-f3de-4667-90a3-f3445889ac9b, name = "" object[14]: 599 bytes, id = 98589d1c-d98c-4a6f-afaf-856f7061d7ea, name = "" object[15]: 6849 bytes, id = 73c928a3-5568-4048-9840-5c4c09c265d3, name = "" object[16]: 1025 bytes, id = 0fe4712a-c0ec-44c5-a656-0b8f061da3a5, name = "" object[17]: 375 bytes, id = f4d5e739-1d1d-4dfe-a5c9-5653a6a11926, name = "" object[18]: 503 bytes, id = 8185396e-e9f5-4238-b4fa-22a78c5818e1, name = "" object[19]: 375 bytes, id = 537cc735-7e7c-4f24-9f5d-25e208d93528, name = "" object[20]: 375 bytes, id = 4431f1f5-f7bf-4dd1-998f-86773b9a5adf, name = "" object[21]: 503 bytes, id = 7df35d66-2a77-460e-80b6-d1cd0323b624, name = "" object[22]: 375 bytes, id = 86378f16-4c2d-47cd-bacb-a0f25a3ff1d4, name = "" object[23]: 1278 bytes, id = 46aa5fc3-1379-47bc-b064-1f73cbaf4168, name = "" object[24]: 680 bytes, id = b25b17ff-c790-4074-b10f-2660fb719176, name = "" object[25]: 680 bytes, id = e521e16f-51d4-4f12-a6a5-25670c6e0d5c, name = "" object[26]: 1278 bytes, id = 62526125-9305-4925-a84a-3260ca13a288, name = "" object[27]: 680 bytes, id = 7e2a4188-da15-4f05-94ee-abee13557191, name = "" object[28]: 680 bytes, id = 041f0637-0bf2-4f74-9bb0-c18f3763a044, name = "" object[29]: 471 bytes, id = 944228c3-ec70-4a2e-a12c-2757662abfba, name = "" object[30]: 2199 bytes, id = be26e30c-ca3f-4e2b-84c5-9c1e43afc08a, name = "" object[31]: 951 bytes, id = ec70889e-12ef-4f2a-b241-1799e65c978e, name = "" object[32]: 1047 bytes, id = 4aeea1b1-a261-4f29-884e-5b9763add035, name = "" object[33]: 3255 bytes, id = 0e65df03-2719-494f-8a20-a0a94e5e032c, name = "" object[34]: 1143 bytes, id = 165fc9cf-dd85-4c02-8f09-53b20b88658e, name = "" object[35]: 535 bytes, id = 15cc861a-1231-4e5f-9aa4-0cb988cb47fc, name = "" object[36]: 535 bytes, id = 616195b6-91b5-453a-8aeb-db9a9ba6edbd, name = "" object[37]: 535 bytes, id = ae7ad627-1385-4a8e-85a5-13a657573e12, name = "" object[38]: 1844 bytes, id = c21c8656-ecf7-425c-b5ca-d27d32ff4b0e, name = "" object[39]: 1058 bytes, id = c2027ae7-7878-4173-9a24-636985eadcb2, name = "" object[40]: 1426 bytes, id = 5c468c12-802d-4ae6-8097-d371b24781e0, name = "" object[41]: 1812 bytes, id = 5364c4a2-8319-4468-8a7a-2521f3cb3337, name = "" object[42]: 4773 bytes, id = 9aa2143e-5df7-4631-8fea-fce4f818457c, name = "" object[43]: 259 bytes, id = 0bcbdf3c-02b3-4605-8c51-9f6fdb9a0c15, name = "" object[44]: 448 bytes, id = c1b7d3a1-edde-467f-bdb5-1ba54c746dd0, name = "" object[45]: 3905 bytes, id = ab704ba7-3828-453d-aecc-bfdcb5459706, name = "" object[46]: 1562 bytes, id = 083d82b2-76ed-42e8-9bef-12799b64aa76, name = "" object[47]: 1217 bytes, id = d1118820-15b9-4e7d-b9e9-c7183eef0c50, name = "" object[48]: 5313 bytes, id = 3c5a521c-d0c4-4075-980c-145373aa83ba, name = "" object[49]: 1537 bytes, id = a2c9c2a0-9d25-4b6f-9a0f-b47556e58331, name = "" object[50]: 1217 bytes, id = 065c6d37-320a-4662-b74f-9e034db9d341, name = "" object[51]: 1217 bytes, id = afa0c545-6bf5-44df-a275-cc513839ad4f, name = "" object[52]: 1217 bytes, id = 03c43edf-ded3-4057-b39c-af48e9dc6d2e, name = "" object[53]: 1217 bytes, id = 4f909bf8-2d7e-4fe6-8a7c-65bd5cf28bfb, name = "" object[54]: 1217 bytes, id = ee8c3004-5daf-4d71-a621-c2e0fba472e4, name = "" object[55]: 1217 bytes, id = 793b2f59-eae7-47ba-b6af-b1334a2950a3, name = "" object[56]: 1217 bytes, id = 208c0fff-8ed2-4ffc-8ca4-4392642498bc, name = "" object[57]: 1537 bytes, id = bca2dbac-0e8b-448c-bd9e-bdbecc794502, name = "" object[58]: 1537 bytes, id = 4ff9e36b-2b2e-4d89-97b6-e390dee52efe, name = "" object[59]: 1217 bytes, id = aab2a669-c6a7-4131-8c34-1cb66b51f52f, name = "" object[60]: 1537 bytes, id = f1ced292-a981-4517-8e4f-f7a607ba64d7, name = "" object[61]: 1537 bytes, id = 70c80132-0efb-402c-8ad7-7bda64a1bc4d, name = "" object[62]: 1537 bytes, id = 3b497334-05da-4c99-805c-003206dc60b5, name = "" object[63]: 1537 bytes, id = fa0f9e82-0392-4b42-bdf1-e35aa6ea567b, name = "" object[64]: 1537 bytes, id = 12fd86c7-046b-4219-97a1-ecda9ff8c726, name = "" object[65]: 2701 bytes, id = f5b42b44-4ba1-48f1-a985-024108634191, name = "" object[66]: 2492 bytes, id = 0e5bfaf4-1544-427b-93fd-bb0dd96607c2, name = "" object[67]: 567 bytes, id = 2279c956-c103-4a27-a14d-dd0762bed89a, name = "" object[68]: 407 bytes, id = 8272a25c-f558-4929-920e-ebc26b3873ce, name = "" object[69]: 407 bytes, id = f9447621-7c51-4e9d-b3b0-5307865a0e97, name = "" object[70]: 567 bytes, id = 6da73d4d-51ed-4fe6-9705-b6028603473c, name = "" object[71]: 259 bytes, id = d534c52f-86f2-4ac7-80d8-f9f0441b8a8d, name = "" object[72]: 407 bytes, id = d8587fec-6fbf-4ed7-b007-776d98d5ae1e, name = "" object[73]: 503 bytes, id = 86da08cb-80aa-474e-8276-b7840c64739c, name = "" object[74]: 471 bytes, id = 65832f15-bac1-400e-a60e-8a55c60f6610, name = "" object[75]: 439 bytes, id = 7fae0aa2-9af1-4f62-a0b5-3dbe31f0c888, name = "" object[76]: 471 bytes, id = ec684dbf-29b7-48ac-9675-2942f3fbde34, name = "" object[77]: 219 bytes, id = a30111ee-5a3a-4c06-867c-5579ba3fd0c0, name = "" object[78]: 227 bytes, id = 864b740f-818b-4cb8-80ba-8ff0ce31bd84, name = "" object[79]: 227 bytes, id = 04a67a27-2584-467b-b226-2ea02de742ac, name = "" object[80]: 227 bytes, id = c2d3e7f8-7706-4513-8d6f-5bcc2d026b4e, name = "" object[81]: 295 bytes, id = fd565333-f0d4-4308-87d6-eca878990d49, name = "" object[82]: 471 bytes, id = 7ee1950d-8373-4c4e-9027-18c6de781d6b, name = "" object[83]: 227 bytes, id = 57adf9e2-c76e-422c-ab35-85d3f6e4103b, name = "" object[84]: 227 bytes, id = 7dd4d828-0a91-4436-b901-84c80e02228b, name = "" object[85]: 219 bytes, id = 1438a7aa-8564-4c02-b0bd-723031a5f69f, name = "" object[86]: 219 bytes, id = bdc582cc-dc81-41a5-924b-6f2fec7541a0, name = "" object[87]: 219 bytes, id = 532ad5af-f5c2-49fa-b398-dd01343c0be9, name = "" object[88]: 395 bytes, id = 15f76ccf-98c0-408f-a81d-90ebab6b7059, name = "" object[89]: 1911 bytes, id = fff64cf2-d2f1-439d-82e0-79d7a1ed2a21, name = "" object[90]: 227 bytes, id = f65be906-87fe-4145-8d66-780eb38205be, name = "" object[91]: 100595 bytes, id = 24565d48-3b50-4145-a056-59d30626127c, name = "" object[92]: 31355 bytes, id = f9b3f288-ced9-40db-8494-ec8dcdb7b4e9, name = "" object[93]: 31355 bytes, id = 25b6fd8f-1184-4de9-88b1-28f7785a6a04, name = "" object[94]: 10403 bytes, id = 29228dbf-df11-485e-9f2f-d8c8fe29078d, name = "" object[95]: 6916 bytes, id = d458cb5b-c53d-427a-9247-4bfdb5ee86d4, name = "" object[96]: 63702 bytes, id = 515a0726-e574-4dce-8537-c69ad3623477, name = "" object[97]: 3146183 bytes, id = 01b511f1-fd5f-4dd9-b467-e939f344213a, name = "" object[98]: 22685 bytes, id = 4dc19b76-4574-4318-88a9-f2ab4441aa29, name = "" object[99]: 19264 bytes, id = 5a420d23-24d7-4607-aea7-45d06ef79f70, name = "" object[100]: 351222 bytes, id = 358542af-7327-4599-9099-3570d478f3a8, name = "" object[101]: 34504 bytes, id = 89b32c54-bdea-4de2-ac71-3fc15c3ad122, name = "" object[102]: 19264 bytes, id = 4101c1ab-dc79-4d9e-9545-d13e36460bfc, name = "" object[103]: 25660 bytes, id = a599c391-72ec-4d24-8e0e-50e6484b4c90, name = "" object[104]: 17150 bytes, id = 9aa15ed8-873d-4ebb-8d7c-46e5d604e779, name = "" object[105]: 60360 bytes, id = d2cded62-9d1f-40fa-b5a6-d46f6f0d3762, name = "" object[106]: 60360 bytes, id = e8873641-7524-4ec8-81f7-ffd54cd05894, name = "" object[107]: 76405 bytes, id = 56430b22-3c6a-4360-88fa-496aceb2af0a, name = "" object[108]: 22565 bytes, id = 771528f8-99fe-410b-a270-e414ea815dad, name = "" object[109]: 22565 bytes, id = 173a4c74-f2e7-46fd-81fd-aea435b4791f, name = "" object[110]: 259 bytes, id = 6b464d2c-1536-42a1-b568-5b4f5328c12b, name = "" object[111]: 983 bytes, id = 92b51851-ad6d-4292-86df-57df0d56dd5e, name = "" object[112]: 2456 bytes, id = 594601cf-7bfb-400d-b2e5-b2f130a688ef, name = "" object[113]: 919 bytes, id = 79bc8ca7-5c7c-4674-9006-6bd552f80c74, name = "" object[114]: 663 bytes, id = 0e595136-74e3-4bb5-adc8-a4457eda97bf, name = "" object[115]: 663 bytes, id = cb52a9a2-700e-43b2-b1d9-cb863b379bc6, name = "" object[116]: 663 bytes, id = 14eca251-b366-4f36-9507-04686fc4eae7, name = "" object[117]: 663 bytes, id = ca4133f6-b74c-468c-a188-e826db262df5, name = "" object[118]: 663 bytes, id = c8c5d54f-cab2-4cc9-b917-5c3f8e6e5364, name = "" object[119]: 535 bytes, id = ffc36835-f177-4755-94ee-60ebd93815f9, name = "" object[120]: 11393 bytes, id = 34f43b65-8c73-4547-84ca-69e996e2511f, name = "" object[121]: 42497 bytes, id = ed44a2f0-3835-4f31-b184-16b815c8e2b0, name = "" object[122]: 503 bytes, id = db3d5a64-5b52-4f4d-a660-798bb4452190, name = "" object[123]: 2231 bytes, id = 3d51b649-5ba8-4692-9eff-632fc0cba3f3, name = "" object[124]: 22755 bytes, id = 24686deb-453a-46c1-8657-e5bd73414eb3, name = "" object[125]: 1217 bytes, id = 9a23481c-6742-46af-a1ff-1ded3acb7537, name = "" object[126]: 599 bytes, id = 24e0c910-ed9e-44d1-a75f-34800f53bf85, name = "" object[127]: 599 bytes, id = 8b9ff6da-142d-4171-b1cf-4233a94c9fdb, name = "" object[128]: 599 bytes, id = 11696b2f-d92e-4836-bab5-65fdb96bbff5, name = "" object[129]: 599 bytes, id = d1050377-8d68-49b9-b70d-40ae6edc632a, name = "" object[130]: 599 bytes, id = 04a55677-c573-438a-b859-265c4e563991, name = "" object[131]: 599 bytes, id = 8fe6674a-60c9-4305-87d8-6894780e09c5, name = "" object[132]: 599 bytes, id = 8a831680-321a-4960-a7b7-96386ecef52b, name = "" object[133]: 599 bytes, id = d531d060-2f34-403e-b721-453002812031, name = "" object[134]: 599 bytes, id = 2f8cd367-ce62-4fc9-bd60-77a16a90f5d3, name = "" object[135]: 599 bytes, id = ff36913e-c4ed-4971-a4ac-314cbb0e454b, name = "" object[136]: 599 bytes, id = f4405f30-98fa-4777-9001-630aa6d3d2e5, name = "" object[137]: 599 bytes, id = 6ddd06bb-bfc4-4527-82f7-0894677675a2, name = "" object[138]: 599 bytes, id = bcfe83b7-482c-4d66-8fee-11da6487b6c8, name = "" object[139]: 599 bytes, id = e57bb22b-cce2-4bec-b8d9-ea57ea1dd4af, name = "" object[140]: 599 bytes, id = d8681dd9-7c48-4ca4-b8a2-f9abdb048236, name = "" object[141]: 599 bytes, id = 361ec369-c2a5-4b73-a5b9-4236f5a38298, name = "" object[142]: 599 bytes, id = 09d29b54-4d53-4a2b-a2d6-1a8d0a4cc1b7, name = "" object[143]: 599 bytes, id = 5583b1d4-2551-4046-9d1b-d17561ab1cce, name = "" object[144]: 599 bytes, id = 2fed2960-0426-4f3a-a30c-9084b30b9748, name = "" object[145]: 599 bytes, id = 2a221162-4648-428b-8f34-f623b2f2169a, name = "" object[146]: 599 bytes, id = f479deca-4693-46ea-938e-85fd7c8a1f3e, name = "" object[147]: 599 bytes, id = e523adb5-075a-47f9-801b-a5554c179fd9, name = "" object[148]: 227 bytes, id = 9ee0d40f-a566-4541-8c0f-74a4611ce364, name = "" object[149]: 4266794 bytes, id = da28b71b-1556-4348-8f9b-2925db11d0b0, name = "" object[150]: 7952718 bytes, id = 3ca85777-0f97-41f4-ae24-7dd78c795f99, name = "" object[151]: 4204774 bytes, id = dc0487f3-c964-404c-9aa7-97091f176e8e, name = "" object[152]: 4207194 bytes, id = 2f7561e2-c66b-4d74-ba9c-71ad746be6b7, name = "" object[153]: 4204630 bytes, id = 3432d4dd-7fe7-4585-b20a-4a69097fddd3, name = "" object[154]: 4207050 bytes, id = fc0beea0-eeed-4338-adb9-b5773ddfc9b8, name = "" object[155]: 4204414 bytes, id = 6cfd5bad-b2f8-4da6-9830-097159a26f73, name = "" object[156]: 4206834 bytes, id = 8fa630ac-2158-4076-890a-239cf3ffd4ef, name = "" object[157]: 4204558 bytes, id = 15731757-ccff-4382-aed2-ca0e86da3358, name = "" object[158]: 4206978 bytes, id = 9d86f4e0-27ee-4fba-89ac-0fb08d4ca0e0, name = "" object[159]: 4204774 bytes, id = 3526f17a-3357-4947-aad4-98301f2353c1, name = "" object[160]: 4207194 bytes, id = 03590fba-777c-4eab-81d1-a92c87622dbd, name = "" object[161]: 4204702 bytes, id = c85ed247-b5a0-487e-8ff1-6787a203e863, name = "" object[162]: 4207122 bytes, id = 406762cc-cdb2-4ce3-a8d9-67e716d9da37, name = "" object[163]: 4204486 bytes, id = ebd024b6-0276-4c90-9a00-3907ba4c5a99, name = "" object[164]: 4206906 bytes, id = 448d6edb-5008-4d94-9323-d9db32c1a477, name = "" object[165]: 4204558 bytes, id = 7cce26e5-9f00-49a6-80dd-858712e4fdb7, name = "" object[166]: 4206978 bytes, id = f0381301-c7da-4ce9-9e40-f5a2b99c7587, name = "" object[167]: 4204630 bytes, id = 058027de-5ecb-4614-9f3d-00ad041baa47, name = "" object[168]: 4207050 bytes, id = f12a3cd8-fe43-4379-801d-bc30da225767, name = "" 169 objects with 11 plug-in data items, 92307422 bytes (offset 34221 to 92341643) History Record Table: 0 history records, 24 bytes (offset 92341643 to 92341667) Model User Data Table: user table[0]: (2777917 bytes) Plug-in name: Renderer Development Kit Plug-in id: 16592D58-4A2F-401d-BF5E-3B87741C1B1B user table[1]: (497 bytes) Plug-in name: Rhino Render Plug-in id: 5DC0192D-73DC-44f5-9141-8E72542E792D 2 user tables, 2778616 bytes (offset 92341667 to 95120283) Archive size = 95120303 bytes (end mark size = 95120303)
