Correct Points for Dimension in Layout View
Hi there,
I am currently working on a script to automate layout generation, cause I have a lot files to process.
Now I am a bit stuck with the dimensions. I want to add them on the layout view, but I cannot figure out the correct Point Positions on the Layout page.
Is it somehow possible to convert WorldCoordinates to Layout? Because World to Screen/Client didnt work that way.
Am I missing something?
Hi @moritzcramer,
Have a look at the attached code and let me know if you have any questions.
test_dimlinear.py (2.0 KB)
– Dale
Hi @dale,
thanks for the fast reply.
I tried the script, and also rewrite it to my use case. But sadly it doesnt solve my issue.
I have a few Objects and I want to generate the layouts automatically. For this I use a bounding box e.g. to also calculate the perspective and so on.
So I have those Points of the BoundingBox which I want to use for the Dimension (no user input). So for this I would need to somehow Project those Points to the LayoutPage. Because I want to draw it on the LayoutPage and not in the “World”
When I use your Script (fitted to my demand) the value of the Dimension is completly right, but the Dimension floats somewhere outside the Layout.
Isnt there a simple way to remap the World Point to the DetailPosition?
Hi @moritzcramer,
In general, if you are in a detail view, then get the world-to-page transformation, using DetailViewObject.WorldToPageTransform. Then apply that transform to your points.
– Dale
Hi @dale,
thank you very much! Thats exactly what I wanted. I am a bit confused, cause its my first time using Python for Rhinoscript. Normaly I am using C# and still have to wrap my head around how this Python thing works :slight_smile:
But it seems that the Points in my case are more or less 0.2mm off in the Y direction?!
Hi @moritzcramer,
Without a code sample, I can’t really help.
But here is another sample that might help you.
test_change_space.py (2.7 KB)
– Dale
Hi Dale, Again,
Did anyone figure out or make a sample script for auto dimensioning an object on a layout.
Ie add dimensions to top, front, side views of an isolated object on the layout.
Like moritzcramer’s query:
“So I have those Points of the BoundingBox which I want to use for the Dimension (no user input). So for this I would need to somehow Project those Points to the LayoutPage”
Hi @lukehickmandesign,
Actually, you want to transform, not project. Here is a sample that works somewhat like Rhino’s ChangeSpace command that should give you a hint how to transform points.
Here are a couple of dimensioning samples that might be helpful.
test_create_and_quote_bounding_box.py (1.2 KB)
– Dale
Thanks Dale, I will continue to beaver away.
Are there many people / teams who are fully automating documentation with auto dimensions and layouts that your know of? Or is this a minority?
Hi Dale,
Hopefully a simple question.
Do you make the dimensions first then change space, or make points then change space and dimensions those points?
cheers mate.(from australia)
If you want to make your dimensions in the model, then I’d do the latter.
– Dale
