I have a corner window, unfortunately I have no idea how to do this in Visual Arq.
In Archicad/Allplan this is no problem.
But my thing is important that there is a solution in time.
I hope someone can help me.
Kind regards
Kind regards
Hello @user28,
How is this corner window? Please, could you send me some documentation about it?
For now, I think you have the following options:
You can create two different windows which intersect in the corner
You can also create a window from a block: https://www.visualarq.com/support/tip/how-can-i-create-customized-doors-or-windows/
You can create a Grasshopper Style: https://www.visualarq.com/learn/grasshopper-styles/
Hello @user28,
You will need to use the _vaSubtractSolids command in order to create the hole in walls correctly. The feature to create corner openings is in our wishlist, so for the moment this is the workaround to achieve it.
corner window.3dm (3.4 MB)
Thanks, i figured this way also =)
Is there any updates on this? I’m looking for a way to create a window style for corner windows specifically, i.e., it only does corner windows. Can the subtract solids command be used inside Grasshopper?
Best
Hi @Filipe_Brandao,
Not for now. For the moment you can use the workflow I explained in the post above.
Yes, you can use the “Subtract Solids” component:
