When I copy perspective viewport to detail in new layout, the detail is displayed in lower-left corner of the new layout and it is frozen. I can neither edit it nor move it inside the rectangle representing the sheet of paper.
I’m not sure what you mean with copy here.
Could you post a file that displays this problem?
Hi Andrew - Well that is pretty weird… No ideas yet. … still digging. Here, if I activate and de-activate the detail, it sorts itself out - do you see that?
Anyway. I can reproduce it with a new shot of CopyViewportToDetail
, so we should be able to fix it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-35645
thanks,
Yes, I see the same behavior.
