All,
Is it possible to copy mapping widgets between objects? I’m doing a couple baltic birch plywood projects right now and have set up the edge and face texture files but creating a three new widgets for each component is a bit tedious.
Thanks,
Dave
Have you tried the command ‘MatchMapping’
Select the object(s) you want to copy mapping to, then type command, then click on source object.
I did. It doesn’t seem to drag the widget along unless I’m doing something wrong.
