When I try to copy a VRay light with the Copy command or with Alt and the Gumball I can do the copy but it’s like an istance (it’s linked to the first) and in the VRay asset editor (Lights panel) I can see only one light not two… For me is a problem and I hope that I don’t need to create every light separately. I would to copy fast them and after edit them one by one… any suggestion?
HI, After you copy the light then on the right panel in light properties you have option to make unique. That will set your light unique and you can then edit it separately. You can select all the copied light and make unique and then it will create each light editable.
Thanks! Solved
Alt+Drag will create instances. Ctrl+C/Ctrl+V will make unique objects.
since I updated Vray to 6.2 Ctrl*C Ctrl+V doesn’t work. copied lights always refer to original
…where is the unique button? Can you show with jpg?
RH7 / Vray 6.2
