Copying buttons
Copying buttons to another toolbar does not work , just control and draging as copy to another toolbar does not work , what am i doing wrong ? as in 8 it works like that
thanks
Can you show a video of the issue @robo?
no video, you can drag the copied button , and let go where you want it but it does not appear there , nothing happends
btw i just tried it again after restart and it works again… very strange
Hi.
it works, sometimes it doesn’t.
2.In R8, copying an icon between groups shows a warning that it cannot be copied here.
In R9, the icon itself appears instead of the warning.
3.When copying an icon within the same group, pressing Esc does not cancel the command — instead, it copies the icon.
Is this true elsewhere or just the popup?
I’ll add an x to the center
  • RH-96927 Show x in center of dragged toolbar item
That’s crappy, that needs fixing
  • RH-96928 Esc does not cancel copy in same group
How weird. I’ll have to try this out, I appreciate you settings this up, it’s very very helpful!
RH-96933 Copying buttons is inconsistent
Ok so it was not just me, was allready doubting myself
I noticed the same problem and reported it over here. Only after that, I found this thread about it.
It’s a beta but basic stuff like this doesn’t work? Of course I’m not going to use the beta if I can’t even setup rhino the way I need it for my workflow.
@hitenter
We’re entering the beta phase when we consider Rhino to be feature complete, it is not related to how many bugs are ironed out.
ok, makes sense, I understand.
I still can not copy buttons , am i missing something ?
I’ve got this YT RH-99887 Buttons can’t copy/move
And I’m trying to reproduce this. Do you get the over the icon and you can never drop it @robo or something different?
yes a sort of red v or x over a button indeed , i can make a new button that works , but no copying
RH-99887 is fixed in Rhino 9 Service Release 2 Release Candidate
it goes to a rhino 7 page Brian
grts
Rob
