Copy with Gumball - Moves original Gumball too
Having an issue now where, if I start moving an object with the gumball, and tap Alt to duplicate the object, the original object’s gumball is now moved as well.
SystemInfo.txt (2.5 KB)
Edit to try Martin’s SystemInfo script…
System Info
Rhino 8 SR5 2024-2-5 (Rhino 8, 8.5.24036.02001, Git hash:master @ 48a8af915bbeb069e8dcce1d9675ec7bbe28abca)
License type: Commercial, build 2024-02-05
License details: Cloud Zoo
Windows 10 (10.0.19043 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.16
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24036.2001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24036.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24036.2001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24036.2001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.5.24036.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24036.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24036.2001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24036.2001
Interesting.
Why do you upload a *.txt file with your system info when you could just copy paste? The McNeel people who are going to look at your system info now first have to download the file and then open in an editor…
Honestly? Because I didn’t know about the Hide Details option, and pasting it directly leaves a wall of text; I had figured this was the simplest option.
But with that said, I like your script and will be using it from this point forward.
Thanks :slight_smile:
I don’t know what the McNeel people prefer and I also dislike the wall of text…
Hi Scott - thanks, a couple of gumball location-not-right bugs have been fixed recently in the 8.6 builds - what you show there does not happen here.
I prefer a wall of text to an attached file, by far, but the hiding trick is fine too.
Hiding it is, then! Whatever streamlines the support and makes life a little easier for you folks.
Looking forward to SR 8.6!
