Is there a shortcut similar to LMB+Ctrl+Shift+Drag, but instead of moving the wires, it copies them instead?
No the only copy-wire thing is if you make a regular wire and right-click while left-dragging. By all the rules of consistency that should also work for ctrl+shift+lmb+drag but it doesn’t.
This is still a highly wanted feature!
Indeed
It’s not there but it’s wanted
One option is to double click on the wire in order to create a relay, then connect from the relay. Not perfect, but often quicker than going back to the original component.
I dealt this with code, creating a relay is a solution, but it expires the downstream components, which is sometimes not desirable.
Can you share a minimum working example of how you achieved that using code that does not expire the pipeline?
it’s part of Melanoplus plugin, I don’t like the current implementation, am working on a newer/cleaner method, but this works for now:
private static void ObjLMB(object sender, KeyEventArgs e)
if (sender is GH_Canvas canvas
&& canvas.ActiveInteraction is GH_RewireInteraction
&& (Control.ModifierKeys & Keys.Alt) != 0)
Type type = typeof(GH_RewireInteraction);
if (type
.GetField("m_input", BindingFlags.NonPublic | BindingFlags.Instance)
.GetValue(canvas.ActiveInteraction) is bool fromInput
&& type.GetField("m_source", BindingFlags.NonPublic | BindingFlags.Instance)
.GetValue(canvas.ActiveInteraction) is IGH_Param from
&& type.GetField("m_target", BindingFlags.NonPublic | BindingFlags.Instance)
.GetValue(canvas.ActiveInteraction) is IGH_Param target)
if (fromInput)
foreach (IGH_Param s in from.Sources)
target.AddSource(s);
else
foreach (IGH_Param r in from.Recipients)
r.AddSource(target);
canvas.Document.NewSolution(false);
subscribe that method to something like canvas.KeyDown
initiate a rewire, and instead of letting go, press Alt to copy the wires.
[ Ctrl + Shift + LMB + Alt]
Nifty! Thank you for sharing.
