Copy Trim Problem
Hello!
Does anyone have any idea why copy trim doesnt work on this case?
Thank you!
Copy trim.gh (7.0 KB)
Because your source surface is “Untrimmed”.
Thank you HS_Kim… But if I would like to orient this subdived pattern on my untrimmed surface how would be a way to do it by keeping its horizontal direction…
Copy trim.gh (33.0 KB)
Your explanation is insufficient. What is your subdived pattern and what is your untrimmed surface? Explain in detail using images or sketches.
Hello HS_KIM!
I would like to orient this random subdivision curves.
to this surface
I used map to surface and surphase morph but the direction of the initial curves changes according to my surface UV and I want to avoid this.
You’ll need pufferfish plugin.
Copy trim_re.gh (27.0 KB)
Just so you understand, Copy trim does not trim with curves. It copies the trim data from one trimmed surface to another untrimmed surface.
Thank you guys!
