Hi!
I’ve been having some issues with copied text in Rhino 8 running on mac.
Could you help me where to set this up or find the reason why it behaves like this.
When I copy a text via copy command it seems that it makes the instance of the text. When I change the original text the instance (or all of them) change also. But when I change the instance itself the original stays the same.
Picture of the example is here:
I did not experience this in Rhino 7.
Is there a possibility to change or turn off this setting please?
Thank you very much for your help!
A.
